Sorry,
For yet another topic but seeing as i'm not german but belgian it'z difficult fot me to understand whats being said.
I'm basicly looking to do this something like this.
http://img259.imageshack.us/img259/20/zukibrakeglow.gif
or this
http://dr-650.de/files_ext/galerie/ ... -304-2.jpg
but i have no clue how they did it or how to start on it.
DR650 SP44 heckumbau
Re: DR650 SP44 heckumbau
The back like shown in the pictures in my previous post. The front is not that hard to change.
Okay i did it exactly like the one in your picture. I just dismantled the plastik that holds the license plate and the brake light .
Your new LED lights will fit with the holes where the old ones have been mounted .For the brake light i had to drill three holes ( the one in the middle has to be 8 mm for the cable.
For the electrical part you need a relais ( only works when your cockpit hat 2 different lights for the 2 turn signals) or you need resistors for every light each.
Eventually you have to cut a bit of the metal from the frame under your license plate if it is to long.
I hope i helped you with my english, i gave my best.
Kindly regards
Kindly regards
