U4gm shares The Hunter's Gambit of Outmaneuvering Captain Hartlin
Alam560
Beitrag von Alam560 »
Captain Hartlin is one of the greatest barriers in Path of Exile 2. He is a ruthless marksman. He is quick and lethal in his attacks. You can not just get up and fight him. You need to know the battle field and make the best use of your PoE 2 Currency . The arena is circular. It has little cover. It is your movement that is most of a test.
His standard assault is a volley of projectiles. These shots hurt a lot. They come out quickly. You must be rounding him the whole time. Do not stop moving. It is a good tactic to remain in the middle. It gives you time to react. It is quite dangerous to get too close. He is shot in the point-blank gunshot. It can kill you instantly.
It becomes a battle when he is two-thirds healthy. He gains new abilities. And he will make a flight to the extremity of the arena. He shouts a warning line. Then he starts to pour a sniper bullet. One will see a large beam on the ground. It shows the path of the shot. You have to go at right angles of the beam. And do not flee straight away. You will get hit.
His shrapnel grenade is another threatening gesture. He throws a canister which bursts into pieces of metal. The fragments are very extensive. They leave burning ground. You do not want to stand that. It limits your space. Watch where he throws it. Go to the untainted side of the arena. You need to position your PoE 2 Currency well to ensure that you do not waste it repairing it.
The last stage is the most violent. Hartlin turns more violent. He employs all his powers one right after another. The arena is filled with danger. You must stay calm. Everything comes second to avoidance of the sniper shot. Find opportunities to counterattack following his completion of a big move. Do not get greedy. It is better than a dangerous assault that has been successfully achieved.
It is important to control your flasks. You will be on the move all the time. Priceless are your life flask charges. Keep them in case you are safe a few moments. A Quicksilver Flask is very useful in repositioning. You can get a Granite Flask and save yourself a minor error. Death is a time, resource, and PoE 2 Currency for sale waster. A good plan will spare your Currency on better equipment according to u4gm.
