2-teilige tank DR BIG
carlo
Beitrag von carlo »
Is it possibel to fit a doubble feul-tank from a DR BIG on to a Dr650RS ?
Answers in germain no problem :wink:
hcw
Beitrag von hcw »
There are a few BIGs with a fuel-tank of the 650 SP44. This isn't fitting without some adjustments. So I think you have to work a bit with it. But this is only a suggestion....
Regards
Christian
... gone fishing ...
joh
Beitrag von joh »
Hallo Carlo, welcome to forum,
sometimes people do it the other way round. Put a different tank on the Big.
As the Big probably has a wider frame, you could do it with some selfmade brackets. But than you need a fuel pump and the fairing wouldn`t fit.
Why are you considering this, tank capacity or optical reasons?
DR 650 SP41B, Bj. 91
carlo
Beitrag von carlo »
I want to built a dakar replica (just for fun).
www.motocarlo.be
Greetz carlo
joh
Beitrag von joh »
Nice webpage,
the DR Big double tanks are probably heavier. I think the older DR Big model has a single tank which might also fit. To balance the weight you could fit some rear tanks.
On the other hand it might be easier to change for a Big, which is more a Rally bike from start (longer wheel base, stronger engine).
Juergen
