Dr650 brake
devilofsky
Dr650 brake
Beitrag von devilofsky »
Hi guys......
if there is a problem that i discovered in my Dr650 sp45 is that it doesn't brake too much...
what can i do to make it work better?
is better change the rotor or the "grab?"
Firstly check if your caliper pistons are working; in case that they don't work, buy the repair kit, change the brake fluid.
To make the brakes do their job better you should buy the steel braided lines for front and rear brakes.
I've got a swimming disc ahead for the front and it's much better then the original one.
That's all for the moment.
devilofsky
thanks a lot... have you some link where i can find what you're talking about?
devilofsky
Hessler's are perfect for your DR, the length of the lines is as long as you need. They got the sign fpr the TÜV (important in (Germany).
The lines from Ebay, i don't know anything about these, because I can't read or speak Italian.
