Dr650 brake
Verfasst: 28 Jul 2008 23:29
von devilofsky
Hi guys......
if there is a problem that i discovered in my Dr650 sp45 is that it doesn't brake too much...
what can i do to make it work better?
is better change the rotor or the "grab?"
Verfasst: 28 Jul 2008 23:58
von Martl
Firstly check if your caliper pistons are working; in case that they don't work, buy the repair kit, change the brake fluid.
To make the brakes do their job better you should buy the steel braided lines for front and rear brakes.
I've got a swimming disc ahead for the front and it's much better then the original one.
That's all for the moment.
Verfasst: 29 Jul 2008 00:19
von devilofsky
thanks a lot... have you some link where i can find what you're talking about?
Verfasst: 03 Aug 2008 14:22
von devilofsky
Verfasst: 05 Aug 2008 10:46
von Martl
Hessler's are perfect for your DR, the length of the lines is as long as you need. They got the sign fpr the TÜV (important in (Germany).
The lines from Ebay, i don't know anything about these, because I can't read or speak Italian.
