dr 650 se problem
federico
Beitrag von federico »
what kind of new carburator could be possibol put on: mikuni flat slide 40 mm o keihin fcr 41 mm?
federico
I have exchanged whit a carburator of crf 250 x (a keihin fcr 37 mm fat slid) and the motorbike has gone on wery well! I don't what is brock but whit anoter carburator is ok!
machmach
Beitrag von machmach »
Dodo:
Genauso isses. Die ... Tommies haben immer so komische Wörter.
Das kommt aus dem Lateinischen, carbo = Kohle.
Schon die alten Römer haben sich so über die teuren Flachschieber aus Japan beschwert.
Hochachtungsvoll!
KF
(Vor Diktat verreist.)
Hi federico,
At Ebay you will find a used original Mikuni BST40 for appr. 50 euro + shipping.
If you want to use a flat slide, the Mikuni TM40 and TM42 will be fine.
In that case an adaptor to the air filter box is required (as far as I know).
But I think it will do if you put your carburetor in an ultrasonic bath.
Look also for the diaphragma which pulls the slider upwards.
When it is not seated well or it is perforated somehow, the gas mix will also be poor.
federico
thank you Ulf!
federico
hi ulf, for you is possible put on the keihin fcr flat slaid of crf 250 x ? coluld be 37 o 39 mm. How can I do an adaptor for the air filter box ?
Ulf: I have a lot of beers in Rome for you! thank you
Hi federico,
I don't know whats required for the Keihin.
But here is the link how to assemble the TM42
http://dr-650.de/viewtopic.php?t ... ht=adapter
You will find all needed adjustments. The specialist in the Forum is MadMaxOne.
And here is the sketch for the adaptor.
Maybe I will visit Bolsena this summer, it's not too far from Rome, 100 km ;-)
federico
ok for bolsena is near roma. when you will be there send me a mail.
my male: sabazio@tin.it
thank you
pramus
Beitrag von pramus »
Keep carefull Federico with such an announce:
federico hat geschrieben:...
Ulf is in such a case a real Beer-Terminator :D :D :D I know it :wink:
Greetings to Italy
- Pramus -
machmach
Wahrscheinlich hat der Bazi italienisches Bier, wenn es sowas überhaupt gibt.
Hochachtungsvoll!
KF
@Pramus: How do you know ???? :D
@federico: I will E-mail you...
@Machmach: I am not afraid of any cervesa !
2004 and 2005 I stayed at Lago di Bolsena, it was the camping place "Val di sole".
So I am looking for a small size pick up, to carry my camper top plus family and me over the alps 8)
