dr 650 se problem
federico
dr 650 se problem
Beitrag von federico »
good evening to all. my name is federico and I've a big probleme to my dr (I as soon as retourne from a trip in libya: 6000 km whith my dr 650: an animol of desert). now, when I start the motor the collector becams red fire. I thougt that the valves were strong: no, there is compression. and so the fase is corect. what is for them? thank you. federico. rome. italy
Hi Federico,
Maybe the air/gasoline mixture is to poor. Caused by dirt in the jets or the fuel filters.
That makes higher temperatures.
Have a look into the carburetor and clean the fuelfilters.
The main- and the idle jet you can clean by compressed air, also the fuel filters.
There is one in the fuel tank and the in the spigot where the fuel hose is attached to the carburetor.
Also check the valve clearance even if there is compression. Intake .10 mm, outlet .2 mm.
After that distance the maintenance is required anyway.
Zuletzt geändert von Ulf am 31 Jan 2008 09:17, insgesamt 2-mal geändert.
federico
Hi, I clened the carburator when I retournd from libya, and I did the valves tollerance. intake: 10 - outlet 20
I'm begining fool!
Hi, found both fuel filters?
And check the level of the swimmer chamber
federico
yes both filter.
For now I have no further idea.
Overheating is a sign of late / wrong ignition timing, but that's just impossible.
federico
the cdi unitit broken?
Absolutly unusual with the SE.
The only thing I can imagine to change the ignition timing is, if the magneto
comes loose and turns a bit on the crankshaft.
So seen at a Husqvarna WR360 (wegde was sheered). Don't know if possible with a DR.
But if it runs with the usual power, it can't be the timing.
Sometimes you can find preignition caused by oil coal in the cylinderhead. It increases the compression and if it glows, it will inflame the gas too early.
Mostly high temperature is caused by poor fuel/air mix. Have you had a look onto the sparkplugs?
They should be light grey / beige. If white = to hot = poor mix. (Black = too rich, too cold.)
Edit: Can you check for the level in the carburetors swimmer chamber.
You can do with a transparent hose (clear PVC or the like) pop it onto the
drain spigot, hold it upwards and open the drain screw.
The fuel level should be 14.7 mm +/-1 (I am not sure, but here are some
experts in the forum who knows exactly) under the splitline.
That can be adjusted by bending the metal tongue of the swimmer slightly.
Seen a car runnig poor caused by a loosen swimmer valve. It turned out a little bit and closed to early by this.
Tac
Beitrag von Tac »
Have you got fuel with low octane in lybia? Try to fill in fresh fuel 91ROZ or higher :idea:
Nördlingen ´08
Crispendorf ´09
VFR 800 FI
DR 650 SE Supermoto
DRZ 400S
Husaberg
Beitrag von Husaberg »
:shock:
I speek english very well!
Prockenweiss und net so schnell!
:lol:
Gruß Husaberg!
Sie kauen Bienen!
http://husaberg.ag.vu/
federico
thank you to all. now I'll see that you have told me and the pick up of the magneto. for the full in Libya I used the 95 octan. the sparks are black.
dankese. is corect thank you in german???
federico
the pictures of my trip in Libya are on line: www.sporcoendurista.it
hans_olo
Beitrag von hans_olo »
Hi federico,
welcome to our forum. May I invite you to our yearly DR-650 Meeting, this year from the 29th to 31st August in Southern Germany near a small town called Noerdlingen. We will have the possibility to show photos via Beamer and sure many of us want to hear about your trip to Libya. And, of course, we could call it "International DR-650 Meeting" then ;-)
I know, it's a long way to come, but sure it will be fun like hell!
Cheers, Stefan
federico
hi. thank you. I hope that I will be in that meeting. but if you german go in Italy (I live in rome) all toghether whit ours dr 650 will go in the mountains near rome and toscana (very hard: look the photos in www.enduristianonimi.it). ciao
federico
the problem it was the carburator! very strange.
